Keypad no. 5 & 0 does not work when pressed. When oven reaches desired temp. it would start beeping & only way to stop it was to cancel.
A model number may help others help you |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: 2004chev  Keypad no. 5 & 0 does not work when pressed. When oven reaches desired temp. it would start beeping & only way to stop it was to cancel. MDL# KEBS107DAL4 KitchenAID OVEN
Here are your parts Replacement parts for WHIRLPOOL KEBS107DAL4 | AppliancePartsPros.comHere is the tech sheet http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204454769.pdfHere is a manual, although it is for newer units it may come in handy https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6342e2edf7772b6e852573440054cfc6/$FILE/4317418%20Single%20Wall%20Oven.pdfTry removing power from the unit for 10 minutes or so to see if the control board (EOC) will reset. The error you see is related to cavity size but this does not make sense as it is jumper settings and they are not going to change. This points to a bad control board. Does sound like you have two different problems. One the error code and the second the buttons not working. Unfortunately there is no info available for the keypad which would allow you to check it with a meter. Buttons not working can be either the keypad itself or the control board. You may want to try the following. On most keyboards a number of keys will use a common circuit (track) and that may be why more than one key is not working. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
