carol kittelson
#1 Posted : Friday, September 26, 2008 7:22:54 AM(UTC)
carol kittelson
I have cheched the drain hose to the disposal and made sure it has the loop required. The wash motor starts but stops after a small amt of water enters. The I force the water to drain with the two cancel drail buttons. I can hear the motor start but it wont drain. I manually drain it with a small shop vac. What do i do now? I down loaded the trouble shooting manual posted by someone earlier. Do I need a New drain pump. Clean it? New water valveterminal or level switch? Circulation pump? Flow switch? HELP PLEASE!
#2 Posted : Friday, September 26, 2008 1:30:00 PM(UTC)
Hi Carol,
Perform the troubleshooting as described in the troubleshooting manual for one of our previous posts: http://forum.appliancepartspros...troubleshoot-manual.html
Here are the break down diagrams for the Bosch dishwasher Model SHU9915 UC/12 (FD 8003-)
carol kittelson
#3 Posted : Sunday, September 28, 2008 3:34:41 PM(UTC)
carol kittelson
Hi Carol,
would the problem be in the circulation sump pump? Is it hard to open and take apart and do I have to be careful of anything special? Could the hose be clogged at the end where it connects to the pump not at the disposal end?
carol kittelson
#4 Posted : Sunday, September 28, 2008 3:35:38 PM(UTC)
carol kittelson
Gene the manual wont load on my computer?
I cant pull it out. do i have to disconnect something below before i can pull it out? I unpluged it. I feel stupid.
#5 Posted: : Tuesday, September 30, 2008 5:17:09 PM(UTC)
Carol,
Unfortunately I do not have enough time to type in the troubleshooting guide. I just checked the link (bosch dishwasher troubleshoot manual) and it works.
carol kittelson
#6 Posted : Thursday, October 2, 2008 10:10:26 AM(UTC)
carol kittelson
Cant anyone HELP?
Bosch DW does not fill or drain properly (Dishwasher Repair)
by carol kittelson 9/26/2008 7:31:47 AM(UTC)
