I have cheched the drain hose to the disposal and made sure it has the loop required. The wash motor starts but stops after a small amt of water enters. The I force the water to drain with the two cancel drail buttons. I can hear the motor start but it wont drain. I manually drain it with a small shop vac. What do i do now? I down loaded the trouble shooting manual posted by someone earlier. Do I need a New drain pump. Clean it? New water valveterminal or level switch? Circulation pump? Flow switch? HELP PLEASE!
Originally Posted by: Gene would the problem be in the circulation sump pump? Is it hard to open and take apart and do I have to be careful of anything special? Could the hose be clogged at the end where it connects to the pump not at the disposal end?
Originally Posted by: carol kittelson would the problem be in the circulation sump pump? Is it hard to open and take apart and do I have to be careful of anything special? Could the hose be clogged at the end where it connects to the pump not at the disposal end? Gene the manual wont load on my computer? I cant pull it out. do i have to disconnect something below before i can pull it out? I unpluged it. I feel stupid.
Originally Posted by: carol kittelson I have cheched the drain hose to the disposal and made sure it has the loop required. The wash motor starts but stops after a small amt of water enters. The I force the water to drain with the two cancel drail buttons. I can hear the motor start but it wont drain. I manually drain it with a small shop vac. What do i do now? I down loaded the trouble shooting manual posted by someone earlier. Do I need a New drain pump. Clean it? New water valveterminal or level switch? Circulation pump? Flow switch? HELP PLEASE! Cant anyone HELP?
