babyavis2008
#1 Posted : Thursday, September 25, 2008 7:11:42 AM(UTC)
babyavis2008
I need instructions on replacing an electronic control/clock overlay p/n AP3672811
made by FRIGIDAIRE if anyone can help please reply.
#2 Posted : Friday, September 26, 2008 12:03:33 PM(UTC)
Remove the protective film from the the back of the overlay, carefully line it up with the new clock and press it on.
Pull the range out of the wall. Remove the rear control panel cover. Remove the screws secured the control board (clock) and switch all wires from the old control board to the new one (one wire at a time).
Assemble it in the reverse order.
Kenmore electric dryer electronic control replacement needed? (Dryer Repair)
by bschless 8/17/2011 12:42:23 PM(UTC)
