tsesay
#1 Posted : Saturday, September 11, 2010 4:00:28 PM(UTC)
tsesay
My fridge will not cool properly, it does not blow air out the top part of the fridge and the freezer is freezing on in the back of the fridge on the bottom. I have tried turning it off and letting it defrost and it works good for about a day and then it does it again.Any help would be greatly appreciated. thanks!
#2 Posted : Sunday, September 12, 2010 4:35:10 AM(UTC)
Replacement parts for FRIGIDAIRE FRS20ZGFW0 Frg(v3) / Side By Side Refrigerator | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
Fridge not cooling enough (Refrigerator & Freezer Repair)
by izook 4/20/2016 10:05:53 PM(UTC)
lg fridge not cooling enough in freezer compartment (Refrigerator & Freezer Repair)
by gregaguilar 7/21/2014 10:01:50 AM(UTC)
GE Freezer and fridge not cooling enough (Refrigerator & Freezer Repair)
by terrynow 9/22/2010 12:22:33 PM(UTC)
