When I turn on either of the left burners on my Jenn Air 88370, both burners come on high at the same time. :confused: It doesn't matter which burner I turn on, they both come on high. Also, the right rear burner is very slow to heat up. Any suggestions?
One of these two burner switches is shorted. You have to check them for continuity to find which one has to be replaced. - The part number for the switch is AP362532 Here are the break down diagrams for the Jenn Air range Model 88370Gene.
