gizmo1
#1 Posted : Wednesday, September 24, 2008 10:58:30 AM(UTC)
gizmo1
When I turn on either of the left burners on my Jenn Air 88370, both burners come on high at the same time. :confused: It doesn't matter which burner I turn on, they both come on high. Also, the right rear burner is very slow to heat up. Any suggestions?
#2 Posted : Wednesday, September 24, 2008 1:56:32 PM(UTC)
One of these two burner switches is shorted. You have to check them for continuity to find which one has to be replaced.
- The part number for the switch is AP362532
Here are the break down diagrams for the Jenn Air range Model 88370
