bcrist7258@aol.com
#1 Posted : Tuesday, September 23, 2008 4:24:58 PM(UTC)
bcrist7258@aol.com
There is water in the bottom of the refrigerator. The drain pan is completely dry. It seems the drain hole may be stopped up, but we cannot find a drain hole. Any ideas?
Drags1998
#2 Posted : Tuesday, September 23, 2008 5:08:42 PM(UTC)
Drags1998
It sounds like the defrost drain is plugged,The drain is behind the rear wall of the freezer, Remove all the food from the freezer, remove the freezer floor, remove the rear wall, you will see an ice build-up at the bottom rear,under the coil. you must melt ALL ice out of this area. When the ice is gone, you will see a hole in the tin shield,I use a TURKEY BASTER to POWER FLUSH the drain, Put it back together and your done!!!!:)
Water in bottom of refrigerator. (Refrigerator & Freezer Repair)
by olddog 8/4/2009 11:10:44 AM(UTC)
