I have a whirlpool apt size dryer that just stopped running.It was working fine with no signs of failure then it just would not turn on.Any ideas?:confused: Can I test it somehow to see if its the switch?
Check your power supply and if that tests out check your thermal fuse. Nat ps. please double check your model number as it will not pull up.
Thank you.I have checked all the power supplies.All good.My washer is plugged into the same cord and works fine.Could it be the tines on the switch.The model# is ldr3822qo.Thanks again;) :confused:
