Ellie69
#1 Posted : Tuesday, September 23, 2008 1:00:21 PM(UTC)
Ellie69
I have a whirlpool apt size dryer that just stopped running.It was working fine with no signs of failure then it just would not turn on.Any ideas?:confused: Can I test it somehow to see if its the switch?
libertyappl
#2 Posted : Tuesday, September 23, 2008 2:01:41 PM(UTC)
libertyappl
Check your power supply and if that tests out check your thermal fuse.
Nat
ps. please double check your model number as it will not pull up.
Ellie69
#3 Posted : Tuesday, September 23, 2008 4:55:14 PM(UTC)
Ellie69
Thank you.I have checked all the power supplies.All good.My washer is plugged into the same cord and works fine.Could it be the tines on the switch.The model# is ldr3822qo.Thanks again;) :confused:
