Fridge Stops Running And If You Tap The Control Box Just Inside The Door It Will Start Working Any Ideas Mine Was That Maybe The Defrost Timer Is Sticking
If you can tap it and it comes back on, I would check for a loose wire. Nat
Thanks I Will Check For A Loose Wire
