JERNIGAN310
#1 Posted : Tuesday, September 23, 2008 12:09:00 PM(UTC)
JERNIGAN310
Fridge Stops Running And If You Tap The Control Box Just Inside The Door It Will Start Working Any Ideas Mine Was That Maybe The Defrost Timer Is Sticking
libertyappl
#2 Posted : Tuesday, September 23, 2008 12:10:54 PM(UTC)
libertyappl
If you can tap it and it comes back on, I would check for a loose wire.
Nat
JERNIGAN310
#3 Posted : Tuesday, September 23, 2008 12:16:55 PM(UTC)
JERNIGAN310
Thanks I Will Check For A Loose Wire
libertyappl
#4 Posted : Tuesday, September 23, 2008 12:21:24 PM(UTC)
libertyappl
Keep us posted.
Nat
