jersuz
#1 Posted : Tuesday, September 7, 2010 6:03:46 PM(UTC)
jersuz
Where is the defrost timer on this model? Its not with the thermostat.
#2 Posted : Wednesday, September 8, 2010 1:30:35 AM(UTC)
It's behind the control panel, a plastic white thing AP2980817
jersuz
#3 Posted : Wednesday, September 8, 2010 3:18:19 PM(UTC)
jersuz
What I would call a control panel,I don't have one the thermostat is the only control I haveand its not there with it I've seen the exploded veiw of the liner parts and it's showing and it shows the thermostat and the defrost timer close by so I pulled the thermostat and the timer isn't thereso that's why I asked
jersuz
#4 Posted : Wednesday, September 8, 2010 3:28:56 PM(UTC)
jersuz
I have a thermostat with a dial no control panel I pulled it out and there was no def. timer with it
#5 Posted : Friday, September 10, 2010 4:38:28 AM(UTC)
The unit looks like it has a kick plate, remove it it may be behind the kick plate.
If not pull the unit forward, remove the lower rear cover (if it has one) odds are it is in there.
Where is defrost timer located on my fridge, plus testing thermostat (Refrigerator & Freezer Repair)
by pmpm 5/28/2009 7:19:22 AM(UTC)
Where is Defrost Timer on My Amana Frig? (Refrigerator & Freezer Repair)
by kaylakirsch 3/23/2009 11:55:25 AM(UTC)
where is defrost timer (Refrigerator & Freezer Repair)
by baldharley 6/5/2008 10:19:33 AM(UTC)
Where is defrost timer? (Refrigerator & Freezer Repair)
by CharleyB 4/28/2008 8:45:13 AM(UTC)
