jersuz
#1 Posted : 15 years ago
jersuz
Where is the defrost timer on this model? Its not with the thermostat.
#2 Posted : 15 years ago
It's behind the control panel, a plastic white thing AP2980817
jersuz
#3 Posted : 15 years ago
jersuz
What I would call a control panel,I don't have one the thermostat is the only control I haveand its not there with it I've seen the exploded veiw of the liner parts and it's showing and it shows the thermostat and the defrost timer close by so I pulled the thermostat and the timer isn't thereso that's why I asked
jersuz
#4 Posted : 15 years ago
jersuz
I have a thermostat with a dial no control panel I pulled it out and there was no def. timer with it
#5 Posted : 15 years ago
The unit looks like it has a kick plate, remove it it may be behind the kick plate.
If not pull the unit forward, remove the lower rear cover (if it has one) odds are it is in there.
Where is defrost timer located on my fridge, plus testing thermostat (Refrigerator & Freezer Repair)
by pmpm 16 years ago
Where is Defrost Timer on My Amana Frig? (Refrigerator & Freezer Repair)
by kaylakirsch 16 years ago
where is defrost timer (Refrigerator & Freezer Repair)
by baldharley 17 years ago
Where is defrost timer? (Refrigerator & Freezer Repair)
by CharleyB 17 years ago
