I was in process of using the self cleaning feature and now the door is locked and have lost the display to the front mounted control panel. Since door is locked I can't access screws of front panel to check fuse or thermal cutout switch (I am assuming the power and display boards are behind this panel). I do have 120 volt power at plug. Any suggestions on how to override door lock or if I am looking in the right place?
The thermal fused are located behind the rear panel on the range, unplug the unit and slide it out, turn off the gas too. remove the rear panel to located the fuses. Nat
