rankell
#1 Posted : Sunday, September 21, 2008 9:01:21 AM(UTC)
rankell
My father-in-law has a side-by-side and the bottom of the Freezer had about 4 inches of ice built up on the bottom inside of the Freezer. Is this a defrost problem or do I need to look at something else?
libertyappl
#2 Posted : Sunday, September 21, 2008 9:10:21 AM(UTC)
libertyappl
The defrost drain is probably frozen or stopped up. you can use a turkey baster and hot water to thaw it out, they also have a defrost drain heater to prevent the problem.
nat
