luebe
#1 Posted : Tuesday, September 7, 2010 12:14:50 PM(UTC)
luebe
please help i have tryed everything...when i flip the breaker and come in here and press sani rinse and heated dry to try to get in diagnosed mode it hasnt worked...does anyone know how else u can get it into hat mode or to reset it?the normal and pots and pan are flashing back and forth right now and sometimes the cancel button works.....please help
Joe / APP Team
#2 Posted : Tuesday, September 7, 2010 12:52:36 PM(UTC)
Joe / APP Team
Luebe,
You most likely have a bad touchpad assembly, and will need to replace it.
Part number: AP4310681
I have attached the technical datat sheet, so you can run the touchpad and diagnostic tests, so you can varify the operation of the machine.
http://www.servicematters.com/d...heet%20-%20W10082651.pdf
Good Luck,
