andy849
#1 Posted : 15 years ago
andy849
Problem starts with error " E5 " and dryer turns off showig on display E5.
Replaced main board .Termostats , termister , heating coil OK.
Now starts works about 10 min , no heat and turns off showing error on
the disolay " hE " which I assume is a heating error.
Any help will be appriciated, please help.
andy849
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
andy849
Andy,
Did you check your venting system for clogs, kinks and the hood for operation ?
You've pretty much checked or replaced everything else.
Yes,
Both of your codes(TS and HE) indicate a heating problem, and if it takes 10 minutes to produce the code(s) now, it is most likely a vent problem.
Also check and make sure there is no air leaks at the blower to inlet seal, blower or exhaust pipe fitting.
I have attached the Technical Data sheet(s) for you to use to reset your codes and run the diagnostics tests, to better diagnose the problem.
You may also want to dry a load of clothes with the exhaust vent disconnected, as a test for proper operation, and confirm that the venting is the problem.
Good Luck,
http://servicematters.co...ibrary/docs/16026881.pdf
