Problem starts with error " E5 " and dryer turns off showig on display E5. Replaced main board .Termostats , termister , heating coil OK. Now starts works about 10 min , no heat and turns off showing error on the disolay " hE " which I assume is a heating error. Any help will be appriciated, please help.
andy849
Originally Posted by: andy849  Problem starts with error " E5 " and dryer turns off showig on display E5. Replaced main board .Termostats , termister , heating coil OK. Now starts works about 10 min , no heat and turns off showing error on the disolay " hE " which I assume is a heating error. Any help will be appriciated, please help.
andy849 Andy, Did you check your venting system for clogs, kinks and the hood for operation ? You've pretty much checked or replaced everything else. Yes, Both of your codes(TS and HE) indicate a heating problem, and if it takes 10 minutes to produce the code(s) now, it is most likely a vent problem. Also check and make sure there is no air leaks at the blower to inlet seal, blower or exhaust pipe fitting. I have attached the Technical Data sheet(s) for you to use to reset your codes and run the diagnostics tests, to better diagnose the problem. You may also want to dry a load of clothes with the exhaust vent disconnected, as a test for proper operation, and confirm that the venting is the problem. Good Luck, :) :) :) http://servicematters.co...ibrary/docs/16026881.pdf
