My door alarm keeps going off so I obtained a new door gasket kit for both doors, side by side, but I cant figure out how to remove old gasket. Is it glued on?
:confused:
The door gaskets are usually applied with zip in screws every few inches. My quess is not the gasket set, but the door switch. I would check the switch with a meter. Hope that helps.
