Kirbo
#1 Posted : Saturday, September 20, 2008 11:35:34 AM(UTC)
Kirbo
My door alarm keeps going off so I obtained a new door gasket kit for both doors, side by side, but I cant figure out how to remove old gasket. Is it glued on?
:confused:
tommyboy84
#2 Posted : Saturday, September 20, 2008 12:06:27 PM(UTC)
tommyboy84
The door gaskets are usually applied with zip in screws every few inches.
My quess is not the gasket set, but the door switch.
I would check the switch with a meter. Hope that helps.
