rhersh
#1 Posted : Friday, September 19, 2008 3:10:39 PM(UTC)
rhersh
Side by side Eterna Series GE. Freezer seems ok but the frige is warm. When this first happened, I found that the motor area was quite dusty and thought that may have been the problem. I vacuumed well and plugged it back in and seemed to work ok, thought I was a genius! Now has same symptoms. Any ideas?
libertyappl
#2 Posted : Friday, September 19, 2008 7:59:31 PM(UTC)
libertyappl
Check the back of the freezer for frost or ice, sounds like a defrost problem, very common occurance.
nat
