Washer will not run. It made a noise and then briefly smelled like burning rubber. Checked belts underneath and they are fine. Lid swith seems to be working. Where do I go next. Power to washer good.
Where did the noise seem to come from? I would check the motor. Nat
If possible check the motor to see if power is going to and thru it. Nat
