kpmirish
#1 Posted : Thursday, September 18, 2008 6:58:13 AM(UTC)
kpmirish
My Maytag dryer is approx. 15 months old, and after a big storm with numerous power surges/outages, the dryer appears to operate normally, but shuts down after approx. 30-60 seconds. It will start up immediately after shutting down, but still will not work properly.
I really don't think it's a motor issue, based on the reading I've done, and the only other explanation I can find is that the control board is damaged, most likely from the power problems. If this is the case, how does one go about replacing this?
I appreciate any help you all can offer!
Kevin
libertyappl
#2 Posted : Thursday, September 18, 2008 7:58:25 AM(UTC)
libertyappl
Remove the rear panel on the control panel and you can see the controls. The control board in inside the little box.
nat
