AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Electric Dryer runs for 30-60 sec. then shuts down after storm
My Maytag dryer is approx. 15 months old, and after a big storm with numerous power surges/outages, the dryer appears to operate normally, but shuts down after approx. 30-60 seconds. It will start up immediately after shutting down, but still will not work properly.
I really don't think it's a motor issue, based on the reading I've done, and the only other explanation I can find is that the control board is damaged, most likely from the power problems. If this is the case, how does one go about replacing this?
I appreciate any help you all can offer!
Kevin
Remove the rear panel on the control panel and you can see the controls. The control board in inside the little box. nat
Dryer Repair
