Replacement parts for WHIRLPOOL GEW9200LQ0 | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979300.pdfThis should help repair it.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf(The taeh that came out say's it's a main thermal over load kit)
Sounds like a fancy way to say a thermal fuse (Item 59 in Section 3)
If you have a meter, unplug the unit, remove one wire from the fuse and check it. It should be 0 ohms. This is the safest way.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Also could be your belt is broken as this unit has a belt switch in the motor circuit.
