The igniters on my Jenn-Aire gas range regularly keep clicking away long after the flame has lit. There is no way to manually turn them off. They're supposed to go off automatically. I can't determine either the cause or solution. I've tried to fix by cleaning but that doesn't seem to work. There are no adjustments that I'm aware of.
Any suggestions?
Joined: 8/13/2008(UTC) Views messages in topic : 3,097
Please post the model number so we can look at your exact model. Nat
Originally Posted by: libertyappl  Please post the model number so we can look at your exact model. Nat The model # is CCG2423W. I can't figure out how to put the model number back into the original post, so I'm putting in this reply. The tag with the model number says it's Maytag. Is Jenn-Aire part of Maytag?
Jenn-Aire is part of Maytag. The spark module is what controls the ignitors, replace that and it should take care of your problem, part # AP3990137 Nat
