The igniters on my Jenn-Aire gas range regularly keep clicking away long after the flame has lit. There is no way to manually turn them off. They're supposed to go off automatically. I can't determine either the cause or solution. I've tried to fix by cleaning but that doesn't seem to work. There are no adjustments that I'm aware of.
Any suggestions?
Please post the model number so we can look at your exact model. Nat
Originally Posted by: libertyappl  Please post the model number so we can look at your exact model. Nat The model # is CCG2423W. I can't figure out how to put the model number back into the original post, so I'm putting in this reply. The tag with the model number says it's Maytag. Is Jenn-Aire part of Maytag?
Jenn-Aire is part of Maytag. The spark module is what controls the ignitors, replace that and it should take care of your problem, part # AP3990137 Nat
