I have a Frigidaire stack washer dryer combination unit. My washer timer will not rotate. I can manually rotate the timer and the washer works fine. I now have this timer removed from the unit, and on my bench. I need help....how does the small round motor; Kingston Model 60; 120 volt, 3 watt motor turn the timer mechanism....? It has a white plastic spring load arm that rotates and pushes the large timer sprocket????? Only identification on this round motor is 5/6 L 60 Hz I hotwired this small motor and it sound okay inside...but the white arm does not turn??????
please help me......
Not sure about anyone else, but we don't attemp to repair the timers, we just order a new one. I can't pull up the model number you ahve posted so I can't assist in looking up a part for you. Nat
