Stiler1
#1 Posted : Monday, September 15, 2008 4:43:56 PM(UTC)
Stiler1
I have a Frigidaire stack washer dryer combination unit. My washer timer will not rotate. I can manually rotate the timer and the washer works fine.
I now have this timer removed from the unit, and on my bench.
I need help....how does the small round motor; Kingston Model 60; 120 volt, 3 watt motor turn the timer mechanism....? It has a white plastic spring load arm that rotates and pushes the large timer sprocket?????
Only identification on this round motor is 5/6 L 60 Hz
I hotwired this small motor and it sound okay inside...but the white arm does not turn??????
please help me......
libertyappl
#2 Posted : Monday, September 15, 2008 6:25:05 PM(UTC)
libertyappl
Not sure about anyone else, but we don't attemp to repair the timers, we just order a new one. I can't pull up the model number you ahve posted so I can't assist in looking up a part for you.
Nat
