Pauliner
#1 Posted : Monday, September 15, 2008 4:17:58 PM(UTC)
Pauliner
When I woke up this morning the frezzer was reading 20 degrees and the refrigerator 50 degrees. after taking off the bach panel I saw that the Condenser fan was not running. I placed a 20 inch box fan near it and shortly afterwards the temps were fine. The condenser fan cost $125 so I want to be sure that I am buying the right part. When I took the condenser fan out I noticed it ran on 11.5 DC volts and it has four wires, red,yellow,blue, white. How do I test it?
libertyappl
#2 Posted : Monday, September 15, 2008 5:27:34 PM(UTC)
libertyappl
Check to see if you are getting DC power to the fan, the power is converted inside the refrigerator.
Nat
Poor cooling in fridge portion of GE Artica (Refrigerator & Freezer Repair)
by gr8filed 2/2/2020 1:57:33 PM(UTC)
GE Side By Side Poor Cooling, frost build up (Refrigerator & Freezer Repair)
by DaveB2 5/19/2011 6:36:03 AM(UTC)
ge refrigerator poor cooling (Refrigerator & Freezer Repair)
by jeff black 9/15/2010 6:28:26 AM(UTC)
GE side by side very poor cooling (Refrigerator & Freezer Repair)
by theplumber2001 7/28/2009 11:05:21 AM(UTC)
Poor Cooling (Refrigerator & Freezer Repair)
by branhamr 6/10/2009 9:58:51 AM(UTC)
ice dam over drain hole causing poor cooling? (Refrigerator & Freezer Repair)
Belarus dtrthesignguy 1/14/2009 6:32:21 AM(UTC)
Poor Cooling / No Cooling (Refrigerator & Freezer Repair)
by WLee 8/6/2007 9:02:58 AM(UTC)
