Can see water running down the back inside of fridge. Will fill up bottom and leak into floor. Ice will freeze up in ice bucket to be a solid chunk. Does not always do it. But very aggrivating
there is a drain hose in the freezer which drains the water from the defrost cycle. it's probably frozen or stopped up. clear that drain line & you should be doing ok. nat
