brammer
#1 Posted : Friday, September 12, 2008 12:26:09 PM(UTC)
brammer
Can see water running down the back inside of fridge. Will fill up bottom and leak into floor. Ice will freeze up in ice bucket to be a solid chunk. Does not always do it. But very aggrivating
libertyappl
#2 Posted : Friday, September 12, 2008 12:39:54 PM(UTC)
libertyappl
there is a drain hose in the freezer which drains the water from the defrost cycle. it's probably frozen or stopped up. clear that drain line & you should be doing ok.
nat
