eoz3106
#1 Posted : Monday, August 30, 2010 1:45:15 PM(UTC)
eoz3106
I have the freezer works, refrigerator does not issue. I replaced the thermostat timer, turned off the unit and completely defrosted, and it still did not work.
I took out the evaporator motor, AP3845420 , and tested it for ohms. It reads OL when I test it. Can I assume that is the issue then? I am testing it completely unhooked and warm if that makes a difference.
Jeff
#2 Posted : Tuesday, August 31, 2010 2:35:31 AM(UTC)
[COLOR="Blue"]I took out the evaporator motor, AP3845420 , and tested it for ohms. It reads OL when I test it. Can I assume that is the issue then?[/COLOR]
Yes as long as you are using a high enough meter scale.
[COLOR="Blue"]
I am testing it completely unhooked and warm if that makes a difference[/COLOR]
It makes no difference.
eoz3106
#3 Posted : Tuesday, August 31, 2010 5:37:14 AM(UTC)
eoz3106
It's a digital one, fluke 111, so it automatically scales. Thanks for the confirmation.
eoz3106
#4 Posted : Thursday, September 2, 2010 5:37:07 AM(UTC)
eoz3106
I installed the new evaporator fan and it works. I let it run overnight, but the refrigerator is only at 50. The freezer is perfect, but the refrigerator is not cold enough...... Ideas?
#5 Posted : Thursday, September 2, 2010 6:12:33 AM(UTC)
Check that the damper in the freezer is letting cold air into the fresh food section (Items 2 and 4 in Section 2).
If a lot of the food in the fresh food side was at room temperature it may take longer to stabilize.
