We have a very old Magic Chef gas oven/microwave wall unit that has been turned off for about 2 years now. My daughter is moving into the house and we cannot figure out how to get the oven pilot lite. Can you PLEASE help us? Thanks
The model number doesn't pull up can you double check the number off the unit itself. Does this unit have an ignitor? or pilot light? Nat
Im sorry my daughter pulled the model # off the micro wave not the oven, They are attached to one another But anyway , she found this #G930-5CKLXM6 for a serial # and A07353JE as a serial # It is an ignitor!
I'm still not having any luck pulling up the model number.... But since it has an ignitor check it for continuity. If the oven isn't lighting that may be your problem. Nat
Thanks Nat, I will do that. Can you give me any idea where to even look on or in the oven to get it lite? That would be helpful. Give me some ideas Please.
Without seeing your model it's a little harder, but if you can locate the oven burner, probably below the bottom plate of the oven, the ignitor should run parallel. nat
