Tracker
#1 Posted : Friday, September 12, 2008 10:38:12 AM(UTC)
Tracker
We have a very old Magic Chef gas oven/microwave wall unit that has been turned off for about 2 years now. My daughter is moving into the house and we cannot figure out how to get the oven pilot lite. Can you PLEASE help us? Thanks
libertyappl
#2 Posted : Friday, September 12, 2008 11:11:08 AM(UTC)
libertyappl
The model number doesn't pull up can you double check the number off the unit itself.
Does this unit have an ignitor? or pilot light?
Nat
Tracker
#3 Posted : Friday, September 12, 2008 2:16:50 PM(UTC)
Tracker
Im sorry my daughter pulled the model # off the micro wave not the oven, They are attached to one another But anyway , she found this #G930-5CKLXM6 for a serial # and A07353JE as a serial # It is an ignitor!
libertyappl
#4 Posted : Friday, September 12, 2008 2:38:08 PM(UTC)
libertyappl
I'm still not having any luck pulling up the model number....
But since it has an ignitor check it for continuity. If the oven isn't lighting that may be your problem.
Nat
Tracker
#5 Posted : Friday, September 12, 2008 5:38:16 PM(UTC)
Tracker
Thanks Nat, I will do that. Can you give me any idea where to even look on or in the oven to get it lite? That would be helpful. Give me some ideas Please.
libertyappl
#6 Posted : Friday, September 12, 2008 8:05:50 PM(UTC)
libertyappl
Without seeing your model it's a little harder, but if you can locate the oven burner, probably below the bottom plate of the oven, the ignitor should run parallel.
nat
Guest (4)
