Noticed upper fridge was hot. Although light in door operates properly, when lightbulb is removed from socket, fridge cools properly. Upon turther testing, when lighbulb plugged in problem returned. Shortly after noticed the fridge issue, freezer started frosting. Freezes food, but frosts badly. Water dispenser works, ice-maker functional, but flap doesn't open. All occurred 4 months after move from TX to AZ. Has anybody experienced similar issues and if so what was the resolution?
Originally Posted by: sm2jones  Noticed upper fridge was hot. Although light in door operates properly, when lightbulb is removed from socket, fridge cools properly. Upon turther testing, when lighbulb plugged in problem returned. Shortly after noticed the fridge issue, freezer started frosting. Freezes food, but frosts badly. Water dispenser works, ice-maker functional, but flap doesn't open. All occurred 4 months after move from TX to AZ. Has anybody experienced similar issues and if so what was the resolution? :mad: Retraction - Fridge was hot. Removed light, and fridge cooled down, but doesn't stay cool enough for food. Freezer stays cold but frosts. All started with light where I initially felt the heat (but when the light is plugged in the light works properly (on when fridge is open, off when fridge is closed))... could this be a short in the light? Will a motherboard correct the issue or will the light kill the new $150 motherboard? Having to use freezer in the house and fridge outside - something has got to give and husband won't let me buy a new one!
