I have a Kenmore microwave spacesaver. Model# JVM1642BB002. The inside and surface lights work, and the fan works. When I push start, nothing happens. I do not have much electronic experience nor the tools to check any circuits. Could this be an easy fix, or should I replace the unit.
Mary, Let me look at the break down. Nat
The model number posted is a GE MW. Is that the number off of the MW itself? Nat
Sorry about that. It is a GE. My brother just stopped by, and gave the microwave a "technical knock" and it now powers on. Now a new problem has surfaced... It will not heat anything up.
That is probably either the magnitron or the transformer. Of course it could be a loose connection or broken wire. Nat
I am not in a 50 mile radius of your business. I am in Maryland. I this worth fixing??
If it is the magnitron or the transformer I'd say no. But if it's a loose or broken wire then yes. If in doubt call a service company in your area, ask them how much a diagnosis or in shop fee is have it looked at. If it's just a wire then it's worth it. if not you can have them remove it or leave it with them, which ever is the cheapest(in home vs. in shop) Natalie
Thanks Nat. I called GE and they informed me that if it was the magnitron or transformer, it is still under warrenty. I would just have to pay for labor. Thanks for your help.
Good, Hope they get you going. Nat
Originally Posted by: MaryB  Sorry about that. It is a GE. My brother just stopped by, and gave the microwave a "technical knock" and it now powers on. Now a new problem has surfaced... It will not heat anything up. do you know what your brother did to make it work mine stoped working there is power running through it fan turns on but when i try to microwave something it does not work.
