MaryB
#1 Posted : Thursday, September 11, 2008 7:15:52 AM(UTC)
MaryB
I have a Kenmore microwave spacesaver. Model# JVM1642BB002. The inside and surface lights work, and the fan works. When I push start, nothing happens. I do not have much electronic experience nor the tools to check any circuits. Could this be an easy fix, or should I replace the unit.
libertyappl
#2 Posted : Thursday, September 11, 2008 7:29:28 AM(UTC)
libertyappl
Mary,
Let me look at the break down.
Nat
libertyappl
#3 Posted : Thursday, September 11, 2008 7:31:53 AM(UTC)
libertyappl
The model number posted is a GE MW. Is that the number off of the MW itself?
Nat
MaryB
#4 Posted : Thursday, September 11, 2008 7:52:57 AM(UTC)
MaryB
Sorry about that. It is a GE. My brother just stopped by, and gave the microwave a "technical knock" and it now powers on. Now a new problem has surfaced... It will not heat anything up.
libertyappl
#5 Posted : Thursday, September 11, 2008 8:07:29 AM(UTC)
libertyappl
That is probably either the magnitron or the transformer. Of course it could be a loose connection or broken wire.
Nat
MaryB
#6 Posted : Thursday, September 11, 2008 8:11:43 AM(UTC)
MaryB
I am not in a 50 mile radius of your business. I am in Maryland. I this worth fixing??
libertyappl
#7 Posted : Thursday, September 11, 2008 8:42:55 AM(UTC)
libertyappl
If it is the magnitron or the transformer I'd say no. But if it's a loose or broken wire then yes. If in doubt call a service company in your area, ask them how much a diagnosis or in shop fee is have it looked at. If it's just a wire then it's worth it. if not you can have them remove it or leave it with them, which ever is the cheapest(in home vs. in shop)
Natalie
MaryB
#8 Posted : Thursday, September 11, 2008 8:55:13 AM(UTC)
MaryB
Thanks Nat. I called GE and they informed me that if it was the magnitron or transformer, it is still under warrenty. I would just have to pay for labor. Thanks for your help.
libertyappl
#9 Posted : Thursday, September 11, 2008 9:13:21 AM(UTC)
libertyappl
Good,
Hope they get you going.
Nat
jzelaya
#10 Posted : Sunday, December 28, 2008 11:15:39 AM(UTC)
jzelaya
do you know what your brother did to make it work mine stoped working there is power running through it fan turns on but when i try to microwave something it does not work.
Power Outage; Microwave Will Not Turn On. (Microwave Repair)
by vscip 12/29/2011 5:24:45 PM(UTC)
by dwnbrwn6 11/4/2011 4:16:16 AM(UTC)
Microwave will not turn on after selecting time and hit start button (Microwave Repair)
by Ted Thomas 11/7/2008 7:40:20 AM(UTC)
