dypotts
#1 Posted : 15 years ago
dypotts
I have the classic problem of ice forming on the coils in the freezer. Thermostat and heater are OK. The defrost cycle can be initiated by pressing the door switch 5 times so I assume the board is OK. The ice starts to form on the left side above the insulation block around the heater wire. Where do the insulation blocks mount? maybe I have them in the wrong place. Takes about 4 months til the hair dryer needs to come out. Help, it is frustrating that it almost works correctly. Dave
#2 Posted : 15 years ago
Not sure if yours is the same but here is an example of a unit that looks sismlar to yours.
https://secured.whirlpoo...75d8e4b85256ab10050123a/$FILE/4322312a.pdf
See page 11 (air blocks)
