I have the classic problem of ice forming on the coils in the freezer. Thermostat and heater are OK. The defrost cycle can be initiated by pressing the door switch 5 times so I assume the board is OK. The ice starts to form on the left side above the insulation block around the heater wire. Where do the insulation blocks mount? maybe I have them in the wrong place. Takes about 4 months til the hair dryer needs to come out. Help, it is frustrating that it almost works correctly. Dave
THIS FORUM IS DEAD!!!!!!! |
