dawggt
#1 Posted : Thursday, August 26, 2010 7:01:06 PM(UTC)
dawggt
Checked the motor and it works fine and the coupler has no broken parts at all. The washing machine makes a humming/grinding noise and the agitator barely moves. The water does drain out of the tube and that's about it.
Joe / APP Team
#2 Posted : Friday, August 27, 2010 8:07:43 AM(UTC)
Joe / APP Team
So there is no spin cycle either ?
Did you remove the agitator and check for something stuck under it ?
It's starting to sound like you've got a bad gearcase(transmission), if you're sure you motor works and the coupler is in tact.
:confused: :confused: :confused:
dawggt
#3 Posted : Friday, August 27, 2010 7:49:09 PM(UTC)
dawggt
Thanks for the information.
Joe / APP Team
#4 Posted : Monday, August 30, 2010 5:17:12 AM(UTC)
Joe / APP Team
Dawg
You're Welcome,
Something else to try,
With the motor out, leave the drive coupler on the gearcase,
Turn the coupler several revolutions in both directions, It should be somewhat easy in the counter clockwise direction (agitate), and will be easy until the brake / clutch engages and turns the spin basket, in the clockwise direction.
If you can feel the gears not meshing, if it jams up , locks up,clunking noise, you've got a bad gearbox, and will need to replace the gearcase.
Good Luck,
Agitator will not spin but basket spins fine (Washer Repair)
by smullins 3/27/2012 7:07:37 AM(UTC)
agitator will not spin durring wash cycle and is making a grinding noise (Washer Repair)
by ngiff81 2/9/2012 7:32:05 AM(UTC)
Agitator will not spin but the water pump still works (Washer Repair)
by woodrujm 4/24/2011 1:04:33 PM(UTC)
Washer agitator will not spin (Washer Repair)
by jtsbryant 8/3/2010 11:10:59 AM(UTC)
Agitator will not spin (Washer Repair)
by Jayjames 5/11/2010 9:06:04 AM(UTC)
GE Washer Agitator will not spin (Washer Repair)
by tycates 7/22/2009 9:23:59 AM(UTC)
agitator will not spin or agitate (Washer Repair)
by mac12345 7/9/2009 12:01:02 PM(UTC)
