I have an Ultrawash that came with my house. At the moment the drain is not working. I have checked the hoses going to the disposal and that is not clogged. Any other suggestions . . the water sprays just does not drain. Anyone have a similar issue or fix?
thanks, Jamie
Hi Jamie, Remove the bottom panel. Disconnect the drain hose (make sure there is no water in the dishwasher) from the check valve (#15 on the break down diagram). Unscrew the check valve and clean it inside. Gene.
Thanks Gene. After reading the various forums I came to that conclusion as well. That was it . .
