gsequel1
#1 Posted : Monday, September 8, 2008 8:01:28 AM(UTC)
gsequel1
I have an Ultrawash that came with my house. At the moment the drain is not working. I have checked the hoses going to the disposal and that is not clogged. Any other suggestions . . the water sprays just does not drain.
Anyone have a similar issue or fix?
thanks,
Jamie
#2 Posted : Monday, September 8, 2008 1:18:57 PM(UTC)
Hi Jamie,
Remove the bottom panel. Disconnect the drain hose (make sure there is no water in the dishwasher) from the check valve (#15 on the break down diagram). Unscrew the check valve and clean it inside.
gsequel1
#3 Posted : Tuesday, September 9, 2008 5:47:08 AM(UTC)
gsequel1
Thanks Gene. After reading the various forums I came to that conclusion as well. That was it . .
