rpconcaildi
#1 Posted : Wednesday, August 25, 2010 8:04:39 AM(UTC)
rpconcaildi
I've looked at the exploded diagrams for Whirpool dryer model LGR5636KQ1 and can not determine which part to order to get heat. Looking at diagram # 3.
In the past a sensor was replaced and got the dryer going for over 1 year. I think it is the same problem.
Should I order :confused:
- Dryer cycling thermostat, L155-25 - Dryer cycling thermostat with internal bias heater. Opens at 155F, closes at 130F, SPST.
Part Number: AP3131939 made by WHIRLPOOL
OR should I order:confused:
Flame sensor - Senses heat from the igniter, allowing gas valve to open.
Part Number: AP2910747 made by WHIRLPOOL
Thanks in advance,
Richard
