I've looked at the exploded diagrams for Whirpool dryer model LGR5636KQ1 and can not determine which part to order to get heat. Looking at diagram # 3. In the past a sensor was replaced and got the dryer going for over 1 year. I think it is the same problem.Should I order :confused: - Dryer cycling thermostat, L155-25 - Dryer cycling thermostat with internal bias heater. Opens at 155F, closes at 130F, SPST. Part Number: AP3131939 made by WHIRLPOOL OR should I order:confused: Flame sensor - Senses heat from the igniter, allowing gas valve to open. Part Number: AP2910747 made by WHIRLPOOL Thanks in advance, Richard
