tomshulski
#1 Posted : Sunday, September 7, 2008 2:23:20 PM(UTC)
tomshulski
Water accumulates at the bottom of the inside of the refridgerator and then flows out to my kitchen floor. I looked all the way in the front bottom and I don't see an evaporation pan. Do I need to take the fridge apart to get to a tube? Any help would be very appreciated. Thanks.:confused:
#2 Posted : Monday, September 8, 2008 12:31:34 PM(UTC)
Most likely the problem is a clogged and/or frozen drain.
Remove the evaporator cover (#201 on the break down diagram) and look for the drain hole under the evaporator. Use a hair dryer and/or a turkey baster and hot water to defrost and clean it.
Check the drain hose (#315 on the break down diagram).
Here are the break down diagrams for the Hotpoint refrigerator Model CTX18GAXJRAA
