Ives
#1 Posted : Monday, August 23, 2010 2:55:20 PM(UTC)
Ives
Worked fine yesterday, wife put a load of clothes in today and dryer never heated up to dry clothes. I read a lot of other posts,. but none of them had same model number.
Need help, hate to call service man if I can DIY. Where do I start? Thanks Ives
#2 Posted : Tuesday, August 24, 2010 8:21:39 AM(UTC)
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%203980060.pdf
I would start by checking the power
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Dennis Stroklund
#3 Posted : Tuesday, August 24, 2010 9:20:21 AM(UTC)
Dennis Stroklund
HI Denman,
i am in experienced in using this site.
Can you take a look at the post I put in the Dryer section at 11:50 this AM.
I need to head to town soon for paarts it is quite a drive and I need to get stated if I plan on getting this fixed today.
Dennis Stroklund
