theprof
#1 Posted : Friday, September 5, 2008 8:28:27 AM(UTC)
theprof
I have a Whirlpool Duet Dryer that is showing an 'E1' error... I thought it just may be lint built up, but I totally cleaned out from the lint trap through the back of the dryer... I still get the 'E1' error... Any thoughts? Thanks!
piercet15
#2 Posted : Tuesday, January 13, 2009 5:37:00 AM(UTC)
piercet15
not sure what that is off the top of my head but the service manual is under the top lid and it says in there.
TechnicianBrian
#3 Posted : Tuesday, January 13, 2009 5:45:04 AM(UTC)
TechnicianBrian
An E1 is a thermistor failure, part #AP3919451. It is located behind the lower access panel on top of the blower housing and is held in place with a couple 1/4 screws. If you use a meter to check the resistance, you will probably find an open circuit.
