maria23
#1 Posted : Friday, September 5, 2008 8:26:07 AM(UTC)
maria23
I own a 6 year old Frigidaire gas dryer model number GLGQ332AS2 and recently all of a sudden the dryer stopped heating. Everything else works, the light inside of it turns on, the drum spins when I turn on the machine, but it simply will not produce any heat! I cannot ever hear that my dryer is trying to turn on the heating element..... What could be wrong with it and how would I be able to fix it?
I read that thermal fuse may be causing this. If there is a thermal fuse in my dryer then where is it located and how do I take my machine apart to get to it?
Any suggestions greatly appreciated.... Thanks in advance!
Maria
lyndam530
#2 Posted : Tuesday, April 12, 2011 3:48:39 PM(UTC)
lyndam530
Maria
Here it is April 2011 and I have the same problem with the same model gas dryer. Any advice? The product manual mentions that one of the two fuses could be out? How do I get replacement fuses and where do they go exactly?
